I bought a new prop but it does not have any place for the ears of the tab washer to fold down into, nor does there seem to be any room for any sort of insert capable of receiving the tabs. Also, the prop shaft does not have a hole for a cotter pin.
Can I drill a hole through the prop shaft (for a cotter pin) without causing any damage to the motor/lower unit? Or is there a better way to keep the prop nut in place?
The motor is a 1996 Force (by Mercury) 120HP outboard.
