how to hook radio up???
John Hawkins
how do I hook up car radio, run it direct to battery, or do i run it throught switch board, don't know electrical stuff good. help
revertmastec
Re: how to hook radio up???
Thats up to you. If you go to the battery you will have a constant drain. If you go to your ignition switch it will go on and off with the key. You may need a constant power source for your memory. I cant imagine the drain of the clock on the radio is that much so it shouldn't use that much power. :cool:
Greg Lawrence
you could also get the water proof covers and box that they mount it too.
