Re: How to get up on 1 ski
Get up one two skis...then kick off the one that doesn't have the extra spot for slalom.
Try to have the spotter get some bearings on where you leave the ski and try to get it as soon as the run is over.
Lol, I think that's a little basic for being considered helpful.
If you are wanting to deep water start, here are a few tips:
Obviously we're starting with one ski here unless you want to get up on two and kick one off. With one ski, you will need to pull your knees to your chest (both feet in the bindings) and try to get at least 8" of the ski tip above the water when the boat throttles up. You will need to stay in the tucked position with your weight back until the ski begins to plane, at that point you will try and shift your weight forward (push hips forward) to help the ski plane out.
Things you might notice at first are the difficulty in keeping the single ski tip from yawing back and forth. It's natural to have this issue, but you'll get control of it eventually. Another item I found of tremendous help is a deep-V ski rope. The rope has a long V (like 3') which allows you to put the tip of the ski in the "V" and hold onto the handle. This keeps the tip straight until you get out of the water when it simply slides off when you get on plane and stand up.
There is also a method called "dragging a foot" when you do the same procedure as noted above, but you start with your back foot out of the binding and try to get up with one leg. The rear foot drags behind until you're on plane when you insert it into the rear binding.
