How to get tach signal from automotive distributor........
Fordiesel69
The previous owner removed the marine distributor from my 165HP six, and installed an all in one automotive one with the coil in the center. I noticed they twisted the two tan wires together and wired it to the B+ on the distributor, and the two dark brown wires together with nothing else.
Although I do not endorse this conversion, I am stuck with making it work to keep costs down and it actually runs nice with it. Now I just need a tach working....;)
Here is a pic you can click FULL SIZE to see the wires I am talking about. Same setup as my 165HP, but this is on a 120HP.
http://image55.webshots.com/855/2/58/85/2193258850044425697UJbnZf_fs.jpg
Re: How to get tach signal from automotive distributor........
ehhh most of the guys here are gonna tell you your boat is not safe and will explode.
Don S
The tach signal doesn't come from the distributor, it comes from the - terminal on the coil.
Fordiesel69
I understand that part, GM placed a TACH terminal on the exterior of the distributor, so what I am asking is what wire(s) do I need to place on that ternimal?
This is how the old setup was:
Do both (-) wires just tie onto the TACH terminal?
http://image55.webshots.com/855/2/58...7UJbnZf_fs.jpg
Don S
Why, you have a marine tach, just use the coil, no need to even mess with your automotive distributor, if you want to know about your automotive distributor, check with a chevy car forum, they probably know.
RogersJetboat454
You should hook your tach wire up to one of these;
http://www.summitracing.com/parts/MAA-9-26309/
Replacing the distributor with a marine grade unit is $481.00 from Summit. Replacing lives lost by being cheap and using a 30+ year old HEI distributor never intended for confined use in a marine environment is $481.00 X ∞.
It's much cheaper to use a marine grade distributor.
