How to fix moeller 12 gal portable tank?? Threads under gas cap cracked near base.
NAVY LIFE
So I bought a used 12 gallon tank in great shape -so I thought for $25. Now when I went to use it I noticed that the
threaded end that the cap screws onto is split near the base. I searched all morning for replacement fill threads but have found nothing.
Has anyone repaired these threads before??
What type of epoxy can I use that will not break down with the gas??
Thanks
airshot
Re: How to fix moeller 12 gal portable tank?? Threads under gas cap cracked near bas
Try contacting the manufacturer and explain the problem, they can think you are the original owner. I do know they replace tanks that split at the seams. You would need a flexible material for the expansion and contraction that these tanks go thru. I am not aware of anything that will stick to the material that the tanks are made from as I have tried to repair that type of plastic before.
Airshot
