1988 force 125 #1251X8C. I want to change the lub in my lower unit, how do I get the lub out.? One piece lower unit non thru prop exhaust. On the starboard side are two screws one vent one fill. How do I get the old lub out.? Also, tilt trim working good, if it failed how would I raise the motor.? 2 wire motor/pump, center trim ram. If I remove the fill plug would I be able to raise it.? Seloc manual sucks.
