How to drain livewell?
Frozen
I have a 88 Bayliner Trophy with 2 livewells. They have one hole in the bottom and that is correct to the livewell pump. How do I drain these?
TyeeMan
Master Chief Petty Officer
Re: How to drain livewell?
You should have a plug for the holes in the bottom. Even if they do go directly to the pump, pull the plug and they will drain out the same hole as the pump, basically they will drain "through" the pump. Seen it before, , ,
