Re: How to do a compression check
You want the ignition disabled during the test as any fuel vapors expelled from the spark plug holes will tend to curl your eyebrows when the sparks from the plug wires ignite those vapors. Activating the kill switch disables the ignition, just like when you fall overboard (provided the lanyard is attached to you).
