Re: How to determine prop size?
Chances are there are marking, you just aren't seeing them. But, diameter is measured just how you think it's measured, after all a prop is a circle!
However, the most import measurement is the pitch, and you can't measure that. You'll have to take the prop to a prop repair shop and they can tell you what the pitch is.
But make sure you look on both ends of the hub first, cause the pitch number should be on the prop somewhere.
