I'm helping my nephew with a 1986 85hp suzuki. It was overheating so we pulled the lower unit (LU) to replace the impeller. When we went to put it back together he pulled up on the shift rod to get it into neutral using a screw driver through the hole at the top of the shift rod. The shift rod came unhitched from the inside and pulled out of the LU until something on the shift rod hit some the top of the whole in the casing. Now we can't get it reseated properly so it's not in deep enough and of course because it's not attached it won't cause the transmission to shift. Any ideas? Does someone have a diagram of the inside so we know what where the rod has to seat in order for the ball/spring mechanism to lock it into place?
Additionally we noticed when we removed the LU that the shift mechanism was difficult to move up and down from reverse, to neutral to forward. It also appears that this shift rod is bent.
Any help would be appreciated.
TIm
TIm
