How to clean spark arrestor
Jimbobo22
How does everyone clean their spark arrestor for those with carburated engines. I tried using compressed air and it did not really do the job.<br />Should I soke it in a solvent?<br /><br />Thanks for any help.<br />Jim<br />5.7L 270 HP tow motor.
Haut Medoc
Re: How to clean spark arrestor
I soak mine in gas, blow out with compressed air & let it dry thoroghly before re-installing.
DHPMARINE
Solvent works.We have a cleaning tank at the shop,so we soak them before the compressed air.<br /><br />DHP
lakelivin
I used mineral spirits, a bit safer than gas, & seemed to work fine. Surprised at how much gunk ended up at the bottom of the pan I soaked it in. Weird how the gunk was totally separated from the mineral spirits, I poured the mineral spirits off into a jar & it looked like new.
blackz3
just sprayed mine with carb/choke cleaner
Jimbobo22
thanks guys for the tips. this forum is great.<br /><br />jim
MrBill
I've always done what blackz3 suggests...use spray carb & choke cleaner, an easy 5 minute job. I do mine at end of season durin winterization and once mid season. Keep the can on-board and do a clean-up while relaxing with a cold one...
jlinder
I use a cleaner they make for air conditioning coils. Found it at a place that sells appliance parts.<br /><br />Just soak it for a while then hose off. Works beautifully and no problem with flames.
crazy charlie
Im with DHP,just did mine this morning in the parts cleaner and finished it off with a can of brakleen to dry it up.Charlie
Northern Eclipse
I use simple green then rinse with dishsoap and water and blow dry with compressed air.
Scaaty
Mineral Spirits.........nuff said
Luna Sea
Hot soapy water works for me. That's what kitchen sinks for right? :rolleyes:
blackz3
tried spray nine and dish soap...thought it was clean till i hit it with carb/choke cleaner...now i know its clean...you will see the difference
BigPoppaG
Originally posted by J.kopec:<br /> I soak mine in gas, blow out with compressed air & let it dry thoroghly before re-installing.
Ditto. :)
