Re: how to clean aluminum?
Here's the scoop....aluminum boat restoration is one of the things I do in the welding business;<br />1. Strip any paint if any.<br />2. Use nylon wheel in a 2500rpm drill to clean corrosion.<br />3. Use FINE S.S. wire wheel for heavy deposits.<br />4. Wash boat with soap and water and rinse well then let dry.<br />5. Us Alumiprep diluted about 3 to one and keep working all areas of the boat with a fine 3M pad (do not let this stuff dry on the boat). Then rinse with water and let dry.<br />6. Then apply Alodine full strength using a brush, keeping the aluminum wet and soak for about 3 minuts. Rinse and let dry.<br />7. Use aircraft or marine "green" zinc chromate primer, cut 40% with toluene. Paint entire boat.<br />8. Let cure for 5 days and paint whatever color you want....any good quality automotive paint or marine paint will do, use something that has a hardner added to it.<br /> 9. Any corroded rivets can be replaced with #10-24 X 1/2" S.S. Phillips TRUSS HEAD screws and flat washer with nylon locking nut. use a drop of 5200 under the head of each screw. use a 3/16" drill bit to drill out the rivet Make sure you drill out the rivets and treat the boat as aformentioned BEFORE you put the screw in.
