how to check timing 60 einrude
buzzman 9403
i have a little rattle in my motor keep double oil in gas /vro 2 compression is 130# each cylinder need to check timing how? :confused: :confused: or could i ck something else ,maybe take off to head check cylinder,got a over heat alarm let cool for 10 min started get a rattle
buzzman 9403
Re: how to check timing 60 einrude
Originally posted by buzzman 9403:<br /> i have a little rattle in my motor keep double oil in gas /vro 2 compression is 130# each cylinder need to check timing how? :confused: :confused: or could i ck something else ,maybe take off to head check cylinder,got a over heat alarm let cool for 10 min started get a rattle
rodbolt
sounds like maybe some piston noise. use the procedure in the service manual. but if it was correct before your overheat its correct now. I would suspect you have scuffed a piston.<br /> good luck and keep posting
voodoo
Double oil is bad enough, with the VRO you could be leaning it out.
