I had a clump of some kind of fluid in my garage from the rear end of my boat. I checked my Nissan 70 H.P. motor lower unit oil and it is fine, and i checked my 6 H.P kicker motor lower unit oil and it is also fine. Both motors have clean oil in them with no water at all. The oil I saw on the floor is a grey color, and it is pretty thick compared to the lower unit oil. I am now thinking it came out of my tilt trim on my Nissan motor, model # NS70A2. It is gray in color but appears to be no water in it. It is pretty thick but I never saw the oil or fluid in the tilt trim unit on any boat before, so I really do not know for sure if that is where this fluid came from. But what else could it be??
I looked diligently for any signs of a leak on the hydrolic lines and hosed and pistons etc. etc. and did not see any signs of this fluid anywhere except on the floor in the garage. How do I go about checking the level and also adding to it if needed? The tilt/trim is working good, but is making a slight squeaking noise when almost all the way up on its way up. Thanks!
