How to check and inspect the......?
airmanjun10
Im completely new to the PWC world and im trying my best to make a wise buy. I need to find ways to learn how to check the impeller for damage along with the drive shaft. I also need to learn how to check the compression of the pistons. Im a jet mechanic and a car mechanic so i could probably figure it out, but can you give me some tips on how to do this? Thanks again
thumpar
Re: How to check and inspect the......?
To see the impeller just get under the ski and look up into the intake grate on the bottom with a flashlight. Compression is checked just like you would a car. Take a compression gauge and put it where the sparkplug would go and give the engine crack to turn it over a few times. Do it for each cylinder.
