I am winterizing my 1976 9.8 Merc for the first time by myself.I am good on fogging carbs etc but am not sure about changing lower unit oil. I have located two plugs/screws, the top one looks like a plug and has "flush" embossed by it.I assume I remove this so that I can see new lube come out. If this is incorrect please advise. What I believe is the bottom drain is not a plug but a screw (may have been a plug at one time?) this is located near cavitation plate. I do not want to break this loose until I am sure this is the drain for fear of removing wrong thing. Please advise.
When putting new lube is it recommended to use a "lube pump" and will the fitting thread into small motors such as this or do I need special size?
I have read a number of articles about winterizing and feel comfortable doing so, but I am confused by this screw on the bottom
Thanks for any advice
