how to change engine oil
Steve Gael
I just bought a boat with mercury 140 hp motor, I don't know how to change the motor oil, any help will help to find the drain and refilled bolts. Thank you.
Starcraft5834
What year is engine? Mines an 87. Oil pan and drain bolt under engine on mine.. others you have to manually pump out
Steve Gael
I don't know none about boats, and I look for oil drain and refill bolts I din't see it at all, I did find the lower unit bolts, but the engine oil did't see it. the year no idea what year is this engine i look for the year on the sides of the engine didn't see it eider. if you have more info please send, thank you.
midcarolina
I would think your registration card or title for the motor would have the year of manufacture If nothing else post up a couple photo's of the motor.......use photo bucket or any other free image hosting service to post pics.
Chris1956
Is that motor a Mercury inline 6 outboard or a Mercruiser inline 4 Sterndrive? Are you trying to change the gear oil, engine oil or both?
