I want to change the antifreeze coolant in my 2005 merc. 496 mag engine with the closed coolant system.
After draining coolant from block by removing plugs and replacing them, do you just add coolant to the reservoir or do you have to run the engine at idle while adding coolant?
I'm not sure how the air gets dispersed in the engine when new coolant is added, as I know this could be a problem if the air is not removed.
Thanks
Thanks
