Re: How To Bypass the Neutral Safety Switch
To check the compression on that engine, you have to be at the motor anyway. (to remove plugs, install gauge, etc.) Get you a bump starter switch from any automotive parts house. To check compression, unhook the plug(s) to the coil (Note, not the coil wire). This is to prevent a spark from happening. Hook one wire of the bump starter to battery positive. Hook the other lead to the S terminal on the starter (the little wire). Manually, open the throttle lever all the way (WOT) with one hand, then hold down the button on the bump starter for 10 seconds. Read your compression and go to the next cylinder and repeat (making sure to record your results) until all cylinders are done. After you are done, unhook the bump starter lead, reinstall all plugs and plug wires and hook the coil plugs back up.
