How to buy from iboats
garbageguy
I need OEM VP riser gaskets and some other aftermarket supplies and would like to get them from iboats. After looking up the riser gaskets, I end up at the VP store every time I try to find anything else to buy (example, engine oil). Can I buy the VP OEM gasket and other aftermarket products at the same time?
Bob_VT
Re: How to buy from iboats
The VP store is controlled and run by iboats ;)
JoLin
Ah! You mean you want to combine purchases from the (iboats) V-P store with purchases from iboats, into a single order at checkout. Good question. I don't think you can but not positive.
garbageguy
Yes, that's it. Also, I think similar to Thalasso's post, once I went to the VP store after selecting OEM engine parts (somewhere along the line), every time I try to go the the iboats parts store, it sends me directly to VP (but I just wanted some boat soap while I was ordering the gasket from VP store).
I'd like to support iboats, and am willing to pay a bit more than what's available from OTHER sites, but it's not easy to navigate your way around to get what you need.
