Hi guys. Another quick question here... I have a Johnson 9.5 and I took the prop off to inspect and change the cotter pin etc. but I'm wodering how tight the prop nut should be? On the inside, the shear pin fits through the prop shaft, then seats into the inner housing of the prop itself. Then a plastic cone shaped prop nut is threaded on with the cotter pin through it.
Judging from when I took it off, It seemed to have previously been tightened finger tight, then backed off so the cotter pin would fit through the nut. Is this the correct method? What risks do over/under tightening impose?
Thanks for putting up with this newbie.
