I have a 1991 Evinrude 40hp just had the prop rehubed when I replaced it on the motor I torqued to the required 10 ft lbs. I have noticed a slight fore and aft movement of (very little) about 1/16 " or less when I pull and push the prop for and aft .
Is this acceptable I did not replace the thrust washer should this be done I used the old one.
Thanks
Tom H
Thanks
Tom H
