Does anyone know off hand how much hyd fluid ounces this trim reservor holds? 1990 force 120hp, 1201X90B. Its the prestolite system. i know how to fill it, just looking for the ounces it holds. I believe the part # is 820545. thanks for any info.
Re: How much hyd fluid does it hold? Force tilt unit
after rebuilding, it takes about 12oz to put a working fill into the new system. If you are thinking of using a force pump on an evinrude then yes, the 2w reservoir should be big enough.
