How much are these twins worth?
n315on
I am looking at purchasing 2 1963 40hp outboards from a guy on Clist. One was said to be running last year and the other is for parts. How much do you think they are worth.
samo_ott
Re: How much are these twins worth?
I have a couple of old 40's that I am currently trying to sell for $200 each. Make sure they turn over and have compression. Everything else is reasonably fixable. Especially since you have two of em.
bktheking
$200 for the pair is not an unfair offer as long as the one that may potentially run has good compression.
n315on
He is asking $300 for the pair. I will take a look at them once I sell my OMC sterndrive. I'll probably offer him 200-250. What compression tester do you guys use? Will any old comp. tester due?
n315on
At first he said they are short shafts but then he measured them and said they are 29''. I asked him were he measured them from and am yet to get a reply. Did they make these in 29'' or im guessing it would actually be 25'' x-long. If so that's what I need.
lindy46
The one on the left is a long shaft. Can't tell for sure aout the one on the right. But look to see if the one on the right has that 5" extension like the one on the left.
n315on
Is the long shaft 20'' or 25'' or 29'' like he said?
Nasbinator
I have this motor. Once I worked the kinks out, it has been a great motor.
lindy46
From the top of the transom clamp (where it sits on the transom) to the cavitation plate is appx. 18-19" on a short shaft, and 5" longer on a long shaft.
n315on
Ok that should fit my boat nicely. I hope I can get them for the right price. Thank you for all of your help.
n315on
How fast should this push my 1983 Renken Bowrider? I'm not really looking for speed but I don't want something that sits and wines the hole time. I will be using this boat as a fishing boat.
F_R
How big is the bowrider? About 28mph.
bktheking
My neighbours 16ft runabout with the 40 does 26mph with 400lbs or so in the boat, closer to 30 with just him.
n315on
Plenty fast enough for me. Now I'm pushing to sell that drive!!
joebob14
As far as what there worth I just picked one up for 100 bucks but its a tiller model.I just got it to fire up today and put the lower unit on it. Cant wait to get it out on the water, As easy as it is to work on I would jump at two for 300 if it came with even one set of controls and a harness.
n315on
Yeah they both had controls and harnesses but I just got word that he sold them both tonight . Soooooo mad!!!!!
bktheking
Re: ghd
Re: ghd
Uh huh, hair striaghteners and motors go hand in hand, at least my gf would say so!
