How many relays for tilt/trim
ripped_78
I have a 1995 Volvo 290DP and the tilt quit working last week (trim works fine) so I figured it was a relay and replaced both just to be on the safe side and after that the tilt still doesn't work. I read a few post already on this subject and read where there are two sets of relays is this true? Do I have two sets of relays for the tilt/trim unit and where would they be?
rndn
Re: How many relays for tilt/trim
Did you check to see if you have power going to and then from the relays? Maybe it's just the switch, or a fuse. It's important to make sure you check incoming and outgoing electricity before you start replacing parts. Replacing parts until you find the one that is bad can get expensive.
Don S
You should have another set of relays near the helm area.
