Re: How many hours on an 80hp merc is good/bad
steve, would not say 550 is high or low, this motor has been around for some time....the weak point on these engines is idle/low rpm running quality.....when these motors get tired, the in-gear idle gets weak...you end up with alot of neutral rpm, and stalling into gear when shifting....if this is not the case, normal maintenance should keep you happy for some time...
