how many cylinders should be running??
soce009
6 cylinder johnson: at idle should all cylinders be running. if you pulled one wire at a time should each one make the engine sound different when pulled(like shut off or change sound of engine running at idle). i pulled one off at a time while in neutral and idling and 4 of the cylinders had no change on engine, one shut off engine, and the other slowed down engine and then shut off (after sending a few volts up my arm). should all cylinders be working at idle or just in gear. I posted a few questions on this motor, appreciate all the feedback, gonna get it checked out at the marina tomorrow or next day, will let you know how it turns out
D
DJ
Guest
Re: how many cylinders should be running??
They all should be working-all the time. You may want to check the compression on all six. They should be 10-15% of one another.
sloopy
is this a two stroke motor!?
sloopy
soce009
IF all the cylinders are not firing, would this cause the boat to stall under load??
soce009
will be the first thing i bring up when i talk to the marina in the a.m. thanx for all your help.
Solittle
With a 6 cyl your engine should not stall if one cyl is not firing. I would suspect that you have more than one cyl out. <br /><br />A plug should jump a 7/16" gap when firing. Check all plugs. That will tell you if you have an electrical problem and if so where. Check the condition/color of each plug.<br /><br />Then follow djohns advice and check compression.<br /><br />The "how to's" to do this stuff are easily found by asking the appropriate question in the red Search section at the top of the page.
soce009
To keep everyone updated who helped with their advice: got all six cylinders firing now, electrical problems, cleaned all grounds, replaced all orings, and replaced some wires 2 connector and 4 connector that was bad, gonna go out this week, thursday, to see how she runs. wish me luck, will let you know what happens, later..
soce009
good evening all, took my boat out today, was having problems when i put it in the water and it was stalling out when i hit the throttle, but found the problem, electrical connections, motor wasn't running on all 6 cylinders... now she is, and it's beautiful...first time i took her out and opened her up. would like to thank all who replyed and for your suggestions...thanks again!!
