Re: How long should it last?
Opinions will vary....<br /><br />But, mine suggests that the engine will last nearly indifinitely if properly maintained and regular maintenence is performed... Assuming it's in good shape now, anyway...<br /><br />You need to check...<br /><br />Water pump<br />Stats<br />Poppet<br />Oil injection inspection (hoses, pump, etc)<br />Warning module (overheat and injection) checks<br />Lower unit lube changes (with inspection of it's condition)<br />Anti-Carb every few years<br />Carb cleaning when necessary (to prevent a lean condition)<br /><br />You get the point... I've basically never heard of a worn out engine, the reason they die, is a failure in one of the systems that if working properly prevents its death...
