How Long Can a 2 Stroke Run Without oil
GWMASON
I always add my oil before adding gas, but somehow yesterday I forgot one of my tanks was pure gas. I have a 1989 Johnson 140 hp 2 stroke. It ran for a while and then would stall and start up again - I estimate I burnt about a gallon. I then checked the fuel filter and you can guess what I thought when the gas was clear. I flushed out the gas and switched tanks. I took it easy and eventually up to high throttle for a half hour or so. It seems to run fine and the compression this am was the same as it has been for years, at 107 to 120. I don't notice any difference in sound that might be bearings. Could I be so lucky as to run that long on straight gas with no obvious damage?<br /> <br />Thanks<br /> <br />George
Silvertip
Re: How Long Can a 2 Stroke Run Without oil
Only time will tell how lucky or unlucky you are/were. It appears you dodged a bullet however.
tiller7104
"How long can a 2 stroke run without oil" LOL about as long as it will take you to right a check for $1800 LOL Sounds like lucked out big time. I have seen engines run on straight gas for about 3 minutes and lock up! Your compression may have been 107 and 120 for a long time but that is quite a difference? The rule of thumb I have always heard is no greater than 10% difference. Hey what ever works! Good luck and keep the oil flowing!
seahorse5
In testing I've run large engines at idle on straight gas for over 2 hours without problems. When power is applied, such as getting up on plane, a motor will be seized or internally damaged in a very short time.<br /><br />Check compression first and/or pull the heads and inspect the cylinder walls.<br /><br />I take it that the VRO system is disconnected and that is why your are mixing the gas and oil.<br /><br />Over the years I've seen perhaps 10 times the number of ruined motors from folks disconnecting the VRO and forgetting to mix the oil, as have ever been damaged by a faulty VRO pump.
tashasdaddy
during hurricane season i fill all my tanks with plain gas, and put red tags on them. this is a waring tag that there is no oil. i do this as i have 4 6 gal tanks and 5 standard 5 gal cans for gererator fuel. go boating you just add oil a tank at a time and go down a bumpy road.
GWMASON
Originally posted by seahorse:<br /> In testing I've run large engines at idle on straight gas for over 2 hours without problems. When power is applied, such as getting up on plane, a motor will be seized or internally damaged in a very short time.<br /><br />Check compression first and/or pull the heads and inspect the cylinder walls.<br /><br />I take it that the VRO system is disconnected and that is why your are mixing the gas and oil.<br /><br />Over the years I've seen perhaps 10 times the number of ruined motors from folks disconnecting the VRO and forgetting to mix the oil, as have ever been damaged by a faulty VRO pump.
GWMASON
GWMASON
You are correct - the VRO was disconnected when I got the boat several years ago and I was advised not to reconnect since there was some risk it was disconnected for a reason.<br /><br />The compression still ranges from 107 to 120 in the cyclinders which is less than ideal but the same as it has been for the several years I have had the boat.<br /><br />I have no loss of power but remain concerned about "hidden" damage.
dakotarmx
wow you got lucky .suprized it didnt seeze on you .if youre compression good and it runs fine .roll with it .you got a free pass
dakotarmx
if it aint broke dont fix it :cool:
