I have a 1970 Johnson 60 HP 3 cylinder motor. This is my first outboard with a themostat. I have run it in a tank for about 15 minutes and can measure the water output in drops. How long before the thermostat opens?
I know the water pump does work as there is water flow when the thermostat is out. I have tested it in my kitchen and it opens at about 160 degrees.
I take it there is a bypass system where the water flows until it opens. I am wondering if the motor is in the tank deep enough. I see water coming out of 2 places above where the lower unit attaches.
I do have a new impeller to install as this boat sat for a number of years before I got it.
Thanks for any insight!
