How far can I jack up the front of the engine without damaging anything. I need to replace the motor mounts. 4.3 ltr V6 I/O. I put a small car jack under flywheel and raised the motor just enough to take the load off the motor mounts. I got out the 4 wood screws that held the motor mounts to the stringer. I want to lift engine a little higher to slide a 1/4 piece L shaped aluminum under the motor mount. Will that hurt anything. I don't want to damage the transom. Stringer are mush!!
Tonight I was able to get the motor mounts out. Had to cut the bolts in two to remove them.
I want access around the stringers to do some stringer repair before I replace the motor mounts.
How far can I raise the engine w/o damaging anything? O/D is still attached.
