Re: How far can I go
ok, how much does the boat weigh, how much weight in the boat, water condidions, and how are you driving? all those will factor in how much gas you use. for example, i have a 12 foot zodiak, with about 350 estimated pounds on board, not counting the boat weight or engine, in water with a slight chop, i can troll all day. same boat, with just me and bare essentials for gear, mainly pdf, on calm water, i have maybe 4-5 hours of cruising, punching it at full throttle just because, etc. get another 6 gallon tank, just in case, and rotate tanks on outings. the spare tank can also help distribute trim of the boat, depending on where its placed.
