How do you test to see if a rectifier is any good?
M Matthew Ryan Cadet Joined Jun 24, 2019 Messages 7 Jun 24, 2019 #1 How do you test to see if a rectifier is any good?
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 51,912 Jun 24, 2019 #2 a rectifier is 4 diodes. you check each pin to pin connection like you would a diode. most DVM's have a diode check setting.
C chuck_boulos@yahoo.com Cadet Joined Jun 22, 2008 Messages 9 Jun 25, 2019 #3 Here's a sketch on how you test the rectifier using an analog meter or DVM. Attachments photo315543.png 87.3 KB · Views: 3
jimmbo Supreme Mariner Joined May 24, 2004 Messages 14,117 Jun 25, 2019 #4 Rectifier Bridges often pass when checked with meters(low voltage and low current) but will fail when subjected to higher voltages and current
