Re: How do you locate hidden stainless steel screws?
Don,<br /><br />I tried that and found all the screws around the perimeter but there are some in the middle and I just can't seem to locate them.<br /><br />Not sure if you saw my other posts, I believe I cured the problem with the boat not reving past 3k rpm, the exhaust flapper valve in one of the pipes broke loose and was stuck.<br /><br />I was going to go ahead with your suggestion regarding the anti siphon valve just to make sure that I don't have debris starting to clog it but I need to get this panel removed to access the tank.<br /><br />Only othe idea I had was a metal detector.
