how do you know?
tuxcedo88
1993 200hp carb evinrude. not always, which makes it worse, but sometimes on startup it takes three or four times for the engine to maintain an idle If I give it gas it will just bog down. Bulb is primed and hard. would this condition be indicative of a carb problem, or possibly a fuel pump?? If I am running ( which when it runs it runs good, sometimes some hesitation ) and I shut it off for an hour, I get the same condition, similar to fuel starvation. Carbs always have to be primed when starting, I believe they are bleeding down when left overnight, Ineed to replace float hardware. Any suggestions would be appreciated :eek:
clanton
Re: how do you know?
Spark test on cold engine, should jump app 1/2 inch gap at cranking rpms with plugs in. I have seen a few of these engine only fire 3/4 cylinders on start up then then when engines warms up and the Quickstart switches to the run sensors,the engine fires on all 6 and runs fine.A long shot.
BassScratcher
Before rebuilding carbs and fuel pumps, you need to eliminate the anti-siphon valves as the culprit. Bypass your onboard tanks with an external fuel tank and run the boat. If your problem goes away, the problem is either the anti-siphon valve or something clogging your fuel tanks. If the problem still exists, I would re-build the fuel pump first. The carbs should be the last thing to touch.
