With food fisher, if you haven't done anything to it recently it is time, if you take care of it, it will take care of you.
At least change plugs, lower oil and do a decarb and if your pump is more than 3 years old change it and get a compression gauge and get a base line now then check it periodically, it is like taking the engines temperature, if a problem starts you will see it in the compression numbers.
Lower oil is the big one, if you don't keep an eye on it and pick up a leak it doesn't take long to trash it and you don't even want to know what they cost.
Says he wants to rebuild the carbs, he hasn't even seen it. Says that is the first thing he does to all engines and he is an authorized Johnson repair facility.
I think I will wait a while, I just purchased my Sea-tow policy so I will take it out Friday and see what happens
Will change the lower oil first, seems simple enough.
