how do you ID an engine???????
Sonny7thb
I have a 85 HP Force engine sitting on a 1989 VIP 16' runabout. Trying to figure out how to ID it???? I cant even find a set of numbers that I think would be a serial number, there seem to be numbers stamped everywhere on it... Any ideas?????/
p://[/IMG]
[/IMG]
foodfisher
Re: how do you ID an engine???????
Look for a tag on the lower cowling/pan where the fuel and throttle cables enter.
Sonny7thb
1988-1989
So would this be a Mercury or a Chrylser, or does it matter when I order parts? I need a head gasket and wasnt sure how to look for the correct parts.............
Sonny7thb
Thanks, I will look there............once I find the number, how can I ID it from there????????/
roscoe
Chrysler went bankrupt in 1983-4, was sold to US Marine.
Brunswick (Mercury's parent company) bought them in late 1989 and started producing their versions of them in 1990.
So you have a US Marine Force engine.
Mercury is handling all parts.
Contact any Merc dealer for parts.
A good online dealer is Crowley Marine, or Dougrussell.com
Most consumable maintenance parts are available here on iboats.
http://www.iboats.com/Force-Outboar...8538372--**********.411713533--view_id.271680
If you find a model number, it will look like
857F9C
In this case, 85 is the hp
9 means 1989
C means production version C
If you talk to someone about parts without a model number, they will give you a blank stare.
You have BLUE CD module ignition.
You have the old style 2 stage fuel pump.
Hope this helps.
Sonny7thb
thanks for the great information........
but I still cant find a dadgum serial number anywhere..........
roscoe
Only 2 places to look.
Under the carb on the inside of the cowl.
Or on the side of the transom mount.
Sticker/plate is probably long gone.
It is not stamped or written anywhere else. sorry.
NYBo
If it still exists, it will be on the port side of the transom bracket.
Sonny7thb
I found a white, faded sticker that has this set of numbers 858P8F
If thats the serial number, does that indicate that it was made in 88' and its version "F" ?????
