How do you find a gear case leak?
oldiron52
I know I have a slight leak in my gear case. My question is what is the best way to find where the leak is? No oil in gear case submerged in water with 5 lbs pressure on it and watch for where air bubbles are coming out?? In advance, thanks for looking?. Scott
Yepblaze
Re: How do you find a gear case leak?
That's what I'd do. I'd go find that ground down bike tube valve stem I made to adapt the bike pump to it.
oldiron52
Do I have the pressure right? 5 psi?
cannonford57
we test 10 to 12 lbs. at our shop...
mmf
better check pressure and VACUUM. I have found several that would not show a leak with pressure (pushing out on seals and "o-rings") but leaked alot when subjected to the vacuum test!
