How do they rate HorsePower (now and then)??
I have a 1986 Mercruiser 3.7L 190hp I\O. Can anyone please tell me how ther rated the horsepower back then and how they do it now, (at the prop, crank, or flywheel)? and if, by todays standards my motor is actually higher or lower in hp than its orig. rating?
wakatoa
Re: How do they rate HorsePower (now and then)??
I believe that in earlier years horsepower was measured at the fly wheel but is now measured at the prop. Not sure when the transition took place or what the difference would be.
OK, now that you have gotten me hooked on that web site, lets cut to the chase: IF we had 2 motors both rated 190hp, one was measured at the flywheel and one was rated at the prop, WHICH motor would actually be HIGHER if you took them both and measured them the same way???
62_Kiwi
The one measured at the prop would in fact be the higher powered motor.<br /><br />A reading of HP at the flywheel would be higher than HP at the prop on the same motor - due to losses in the drive train.
Exellent and correct answer. Here is what I just found: There are two specific places to measure horsepower: Brake Horsepower (BHP) is the horsepower at the engine flywheel while Shaft Horsepower (SHP) is the horsepower at theshaft, i.e. after it goes through the transmission/ reduction gear. There is generally a 3-3.5 % loss of horsepower as it goes through the transmission.Usually comparisons focus on BHP. Thanks All!
skier
Is that for automotive engines or marine engines???<br /><br />I was told that everytime a drive shaft takes a 90 degree turn you loose aprox 10% :confused:
Lark40
The drop for automobile engines was about 25% when that industry made the ratings switch for the 1972 model year.<br /><br />So, the 3% reduction noted above sounds low to me.
ODDD1
the typical loss for a stern drive is 8 to 10%....marine stuff changed around 1988?....the '190'designation was generous at best...dont get me wrong, I like these 3.7's.....just that 180 was a more accurate assesment...
