Re: How do I use my new compression test kit?
there will be some slight variation in procedures, as you will see, but here's how I do it:
Make sure the battery is fully charged (12.65V or more)
Start the engine and let it idle up to operating temp.
Disable spark by pulling the emergency lanyard.
Remove the spark plugs and inspect 'em, noting any differences between the two.
Screw the compression tester into the #1 spark plug hole.
Spin the engine with the starter - let it turn 3 or 4 times.
Repeat a couple times.
Write down the PSI from the gauge.
Reset the gauge.
Remove it from #1 and repeat the process for the #2 hole.
Google "reading spark plugs" for some interesting reading whenever you have some spare time.
