dancamp009
- Jan 13, 2007
- 64
Hi, I need to know how to set the points and timing on my old Johnson TD20 5 hp outboard. It is year 1945-49. It uses the older type coil system different from any of the others. It has two sets of points which I think I've adjusted okay to .020 (though I'm not sure I did it correctly), and now I need to set the timing. Not idea how to do that.
Also, before I took the top off I tested the spark and didn't noticed very little, if any, spark coming to the spark plug. Is there a way to check the coils on this too?
Any help would be appreciated.
thanks
thanks
