Re: How do I time a Suzuki?
Well, if you have a timing light, go ahead and check it. Top cylinder is no. 1, But don't know the specs. BTW, on an outboard, you check the timing in gear, so you will need to make a jumper to bypass the neutral safety switch. I would guess about 2-4 degrees BTDC at idle around 500-700 rpm in gear. WOT somthing around 20-23 BTDC. If timing is making your symtoms, it will be off pretty badly, I would think, so you can use these as a benchmark. Your suzi dealer can give you the specs if you call them. <br /><br />Things I would check first are, are the carbs in sync?(if has 2,3) Is the primer bulb firm when running? Sounds like it's not gettting fuel, personally, I would take, at least, the bowl(s) off the carb(s) and spray with power tune or sea foam. Make sure float(s) not stuck. Gasket sets for carbs are really cheap, and you can probably do it yourself. I would do this, if it hasn't been done lately, reguardless. Check this stuff, find out what you can, and if no fix, come back, we'll get it strait.
