Re: How do I tell if the boat is sound?
Chris, I have sailed one of the twin keeled boats. As I remembered it did not point well, and it was very slow. That may not sound bad to you now, but when you learn to sail it will become a problem. The twin keel boats are used alot where you have a large tidal change. England for an example, I was looking for one specifically a few years back because of the shallow water I would be sailing in so I sailed one and was not real pleased. If you already have it go with it and enjoy, but if you do not, take another look around and see if you can find something with a single keel. just my two cents. The one cool thng about them is when the tide goes out she stills rides flat. Thats what they were designed for. Things to check: check the standing rigging, I would guess it has never been changed. It is most likely time for new standing rigging. Look for grounding marks in the gell coat. Look for blisters, the death of a sailboat hull.But as I remember that manuf. had a good rep as far as good glass below the waterline which showed in very few blisters with their boats. Check to see if it has ever been sunk, check in bilges for water marks. Check for soft spots in the deck, espically around the mast step area. Check around side stay plates to see that you don't have water leaks through the deck around those areas where the stays attach. Sometimes you can find evidence of water leaks inside on the ceiling, and bulkheads. Does it have servicable bilge pumps. 110 volt elec. system on board, or will you be 12 volt only. Check cushions inside for mildew, on and under cushions, does it smell musty. Mold can be a real problem on some of the older sailboats. What kind of shape is the fuse panel in, will it need to be replaced, check all the elec systems to see that they operate. Last but not least does it have a place to set your drinks in while sailing, you must have a swivel place to set your drink. If you have any que. please don't hesitate to ask. Don
