Hi. I bought a 1988 Johnson Sailmaster 4 hp with a primer pump I can’t locate anywhere the proper starting technique for it. I turn the fuel on, pump the fuel to get it to the engine, turn on fuel valve and pump the primer till tight. It’ll never start and the spark plugs are dry. If I give a shot of starting fluid in the air baffle it starts on one pull and runs excellent!
I think the primer tube is plugged in the carb because if I keep trying to pump it, it’ll overflow out the tiny tube to the carb from the pump and the primer gets very tight due to pressure.
Does this sound right?
Anybody have an owners manual or starting instructions for similar and maybe suggestions on the priming?
Thank you very much! Herb
