How do I remove throttle to replace trim switch?
SlurpJ
Boat is a 1994 Sea Ray 170 that the trim switch is starting to go out on. I can't seem to find anything online for this particular throttle assembly. I've got the throttle only button out but it doesn't look like there's a nut behind there. Is there a set screw I should be looking for?
stonyloam
Are you sure it is the trim switch in the control and not the trim limit switch on the outdrive. What are the symptoms?
