Re: How do I remove my Prop
Like Bob_VT said, it'll slide off.... IF the guy before you lubed the shaft before putting the prop back on the last time. If not, you sometimes have real problems getting it off and a puller may be required.<br />Routine maintenance requires you to remove the prop, clean & lube the shaft, & reinstall the prop at least once a year. If you do, it'll slide off when you want it to.
<br />Backlash
