How do I properly torque the bolts?
massimofinance
I am rebuilding my 115HP Evinrude, and have to tighten the bolts for the Cylinder Head and the connecting rod cap. The book says 18-20 FT/LBS for the head, but when I set my torque wrench (automotive) to some place below 20 (it starts at 20) It is tight and I am careful to not blow the bolt out. (Do I need to buy a smaller torque wrench?) Is automtive and Marine torque wrenches the same? The book says I need to use special torque socket part No.: 331638, what exactly is that?<br /><br />Thanks MAX
OBJ
Re: How do I properly torque the bolts?
Max...you'll need to torque the head bolts in at least three stages and nothing less than two. I start at 10lb and go around, then 15 and then 20. Start at the middle head bolts and work outward in a clockwise pattern....counterclockwise is OK to... :) If you don't have the correct torque wrench, buy or borrow one....don't guess. <br /><br />Would the book be referring to the socket for the rod caps? If so, just pop into the auto parts store and get a 12 point socket of the size ya' need. Torque the caps like the head bolts...three stages.
Trent
For torque that low you will need an inch pound torque wrench. To convert 18 ft lbs to inch pounds multiply by 12.
