How do i mount this? 2horse
  • No plywood
    Votes: 0 0.0%
  • One piece on the front
    Votes: 0 0.0%
  • Noy sure
    Votes: 0 0.0%
  • Total voters
paintitup12
I got this 2 horse and im not sure about mounting it. My friend told me to put a piece of marine grade plywood on each side and attach it to that. Should i?:eek:
steelespike
Re: How do i mount this? 2horse
Need a little more info.Why won't it just drop on the transom?
Plywood on each side of transom would make it something like 3 inches
thick way more than the clamp would fit.
If the present transom is too thick you could bolt a piece of 3/4" ply to the outside of the transom. Motor would be a little high but it shouldn't matter at the speed of a 2 hp.
If the inside is not glassed you could chissel out enough so the clamp will fit over.
paintitup12
it cracks its made as a sail boat boat can have a motor should i put like plastic or somethin Im hopin to get maybe a thin metal sheet
