Re: How do I measure a prop?
Just grab a tape measure and extend the tape from the center of the hub to the outermost tip of a blade and multiply by 2. I'd suggest that you find out where your nearest marina or marine supply store is and take the prop with you, they should easily be able to tell you anything you want to know and give you some ideas about what blade type and/or pitch would optimize your performance.<br /><br />Edit: Nearly forgot, they will probably ask the size and what type of boat you have and what RPMs you're running at WOT, what your hole shot is like, etc. I've been out of the prop biz for about 10 years now so I'm running with basic info, I've forgotten most of the good stuff, my apologies. Hopefully someone else here has better info than I.
