Re: How do I know wich V6-block? (183 or 165 cu.in)
I'v got 21 footer 7,8ft wide, sideconsole(?!?) weights around 2000 pound (full loaded)<br /><br />I'm looking for 55 knots for "everyday use", now i'w got 48-49 knots.. Cheap and easy as possible, as I said here is't knowledge, and I'm not an engineer or even good mechanic. I know theory, but never done anythin like rebuilding.<br /><br />To do list for speed: lift trim tabs, so I can take then out of water. Fix hull "smooth" as possible (must have antifouling). Find optimal engine height. I'm also thinking lift, lift may cause balance problem.. ofcourse looking for best prop. And find couple extra HP (95 octane gas).<br /><br />Only part wich is missin, is engine power. I was told 2,7l heads in a bigbore give around 25hp, and smoothing crancase etc. edges gives also 25 hp. (i'm trying to buy 3,0l V6, they are almost same price as pistons etc. wich I need if I bore 2,7l to 3,0l.)<br /><br />So result should be; I'v got over 100km/h or 55 knots (63mph)
